Husqvarna Updates for 2005
Motomaniaco
Registrado em: 24 Mai 2004, 14:25
Mensagempor Motomaniaco » 21 Set 2004, 16:07
Essa maquininha ai deve empurrar legal nas pistas :twisted: :twisted:
Engine Changes for 2005
Larger Diameter Titanium Valve Stems - Improved Strength and Valve Seating
Metal Head Gasket - Improved Cooling
Revised Back-up Kick Starter System - Improved Strength (optional equipment on motocross models)
Stronger Generator on Enduro Models - Improved Power Output
Starter Clutch on 250
CNC Hard Annodized Aluminium Clutch Basket on 450 - Improved Strength
450 Engine Has New Rebalanced Crankshaft with Larger Diameter Wrist Pin, New Roller Bearings, and New Connecting Rod - Improved Strength and Less Vibration
Polished Camshaft on 250
Keihin Carburettor with Redesigned Intakes - Hot/Cold Double Choke System with "Hot Start" Button
New Intake Cams on 250 and TC 450/510 - Improved Torque
Lighter Crankshaft on TC 250 - Improved Throttle Response
Smaller Crankshaft Bearings on TE and TC 250
New Intake Duct on TE 250 (same as TC '04) - Improved Air Flow
Chassis Modifications for 2005
Revised Suspension Settings
Shock Absorbers with New Sealing Rings and Lighter Reservoir to Improve Efficiency
Lower Shock Linkage features a Roller Bearing and All Needle Bearings in the Rear Suspension are Longer on TE models
Solid Rear Brake Rotor - Improved Pad Life
TE Models have Axles with Clip for Rapid Removal
TC Models feature 240mm diameter Rear Disc Brake and Smaller Brembo Caliper
TE Models feature Shock Absorbers with Bottom-out Spring plus New Sealing Rings and New Reservoir Tank
Radiator Overflow Tank (TE models)
"Holeshot" Starter Hook on Forks (TC models)
New Front Brake Master Cylinder
Electrical System Updates for 2005
Generator with Improved Battery Recharging Circuit on TE Models.
Timing at 0 RPM Modified to Ease Starting
Solid 1-piece Flywheel on TC 450/510
New CPU with Throttle Position Sensor and Gear Sensor
Switch on Clutch to Prevent Accidental Starting
Bodywork Changes for 2005
New Bodywork and Fuel Tank derived from TE 510 Centennial Model (new rear fender, side panels, shrouds and tank)
New Headlight Fairing (TE models)
New Front Number Plate (TC models)
Front Fender Reinforcement
Sds,
Motomaniaco - Jansen Lawall
Marcos
Registrado em: 29 Jun 2004, 10:59
Mensagempor Marcos » 21 Set 2004, 16:47
Esta moto é muito parecida com o modelo "TE 570" (modelo fora de estrada). Com algumas adaptações ... creio que seja capaz de transforma-la em uma motard.
Da uma espiada no site: www.agrale.com.br
Mensagempor Ventania » 21 Set 2004, 17:02
MOTOMANIACO, TUDO BEM.
COMO GOSTO MUITO DE VER TODAS AS MOTOS QUE VOCE COLOCA AQUI NO SITE E ENCONTRO AS FOTOS DELAS EM TODOS OS LUGARES DO SITE, PORQUE VOCE NÃO CRIA UM TÓPICO SÓ PARA POSTAR, TODAS AS PRÓXIMAS QUE VOCE GOSTA.
CRIE UM TIPO ASSIM: TODAS AS MOTOS DO MOTOMANIACO, POR EX. COLOQUE, NOS ASSUNTOS INTERESSANTES.
DAÍ, FICARÁ FÁCIL DE ENCONTRAR TODAS AS MOTOS QUE VOCE POSTOU OU POSTARÁ, DE AGORA EM DIANTE, VIRARÁ UM CATÁLOGO DE MOTOS DO MOTOMANIACO, O QUE VOCE ACHA?
Motomaniaco
Fotos
Mensagempor Motomaniaco » 22 Set 2004, 10:40
Ventania escreveu:MOTOMANIACO, TUDO BEM.
OK
Sds,
Voltar para “HUSQVARNA”
